Advice needed on painting fascia
Old 07-24-15, 08:42 AM
Received 2 Upvotes on 2 Posts
I am gearing up to paint the fascia all the way around. New roof was put in back in January, so all new fascia 1X4 the wood was pre-primed by the roofer I just need to get a coat (or two) of paint on it. The fascia is about 10' off the ground.
I plan to paint the front, the bottom "lip" which is only 3/4" thick and the inside of it.
It's 1X4, but there is a 3" galvanized drip edge over it so only about 2" of it is "exposed".
Given that what is the best way to paint it? I don't think a roller help much being that it's so narrow and the drip edge is in the way. I am thinking using a roller to roll the bottom edge only, walk all around with it with an extension pole. But when it comes time to paint the face it would have to be a hand brush on a ladder right? Is there an easier way? Some sort of a magic fascia "edger" brush?
I also wonder if it's faster painting the front of the fascia all the way around, then the back of the fascia, or would it be faster to paint a couple of feet in the front, flip the ladder to the inside, paint the back of the fascia, move back to the front and do one single pass while doing both sides.
Thanks in advance for any comments.
Old 07-24-15, 08:46 AM
Received 754 Upvotes on 659 Posts
IMO it's easier to brush the whole thing as you go - less ladder moves. There are small rollers that could be useful on the fascia. Describe the soffit? is it painted the same color? aluminum?
a small roller like one of these - http://www.lowes.com/pd_144257-11591...d=3013608&Ntt=
Old 07-24-15, 09:03 AM
The soffit is not the same color or even wood. It's an older house so the soffit is actually made out of mortar. They originally nailed metal lath to the underside of the rafters, then they applied a thick coat of cement mortar from below. I saw the "rough" side of the cement and lath when they redid the roof and had part of the rotted decking off. Must have been real labor intensive back in the days to make a soffit/eave out of wet mortar applied from below.
Old 07-24-15, 12:19 PM
No biggie, just means you have to use more care cutting in the backside of the fascia. It would be too much work now but next time you do a full repaint you might consider painting the backside of the fascia with soffit color as it will save you some time.
