Colors to hide slapbrush texture, and design idea thoughts
Old 08-07-15, 06:05 AM
K
My entire house, walls and ceilings are slapbrush textured. I'd really like to redo the living room/kitchen, but I'm trying to find a color that can hid the texture more. Its an open, A-frame room with wood beams I love the idea of adding a beadboard ceiling, like in the picture, but I'm also worried the beadboard and slapbrush textures will clash. There is way too much to replace all the drywall or try to sand it down, so I'm stuck with it until we move somewhere else. I'd love to do a matte light grey/green color, but can't decide if it will highlight the texture or reduce it. Name:  erica+1.jpg
Old 08-07-15, 07:33 AM
Received 1,198 Upvotes on 1,153 Posts
Any thought to skim coating the walls with joint compound to hide the texture?
Old 08-07-15, 07:45 AM
K
I think they stick out too much to skim coat, but I can always look again and see if the thick parts can be sanded down.
Old 08-07-15, 07:50 AM
C
Received 122 Upvotes on 98 Posts
You might try a wide blade paint carbide hook paint scraper to remove the high parts. Used with a light touch it does a pretty good and fast job of knocking off the highs and making it easy to skim coat.
Regarding hiding it...don't know about best color, but a flat sheen tends to hide variations in texture better...at the cost of being harder to clean.
And if you can arrange the lighting in the room so it is diffuse, and hits the walls dead on rather than at a low angle to the wall, that will help too. Light coming from the side tends to highlight texture.
Old 08-07-15, 07:58 AM
Received 757 Upvotes on 662 Posts
Dark flat paints will hide the texture more than others but I agree scraping the walls and skim coating would be a better way to go.
Old 08-07-15, 08:00 AM
K
Thanks of the scraper recommendation. No way to change the lighting, as the entire south wall is floor to ceiling windows, and the only other light is a ceiling lamp. Great in the winter though, it' ll be 70 degrees inside and 10 outside with no heat .
