Window wood frame has white spots after staining
Old 08-07-15, 01:02 PM
D
I just finished sanding my window wood frame and after staining a lot of white spots showed up in certain areas. Can't understand what happened.
I cleaned the frames with mineral spirits before staining. It didn't happen on all of them
Old 08-07-15, 02:01 PM
Received 758 Upvotes on 663 Posts
Did you sand them any first?
Old 08-07-15, 04:46 PM
XSleeper's Avatar
Received 1,748 Upvotes on 1,572 Posts
My guess is that the white areas are where you didn't sand all the way through the old varnish, and it didn't accept the stain because the wood is still sealed with the old varnish.
But what kind of thinner did you use? I hope it wasn't the low VOC kind.
Old 08-07-15, 08:57 PM
D
That's possible, keep in mind that I am far from being a professional. This is the first time I attempted something like that. I didn't use any thinner, I cleaned with mineral spirits before staining.
Old 08-07-15, 09:04 PM
D
I am wondering whether I sanded enough...
Old 08-08-15, 03:20 AM
FYI - mineral spirits is a paint thinner
