Can I use epoxy paint over unfinished wood?
Old 08-10-15, 07:07 PM
N
Received 1 Upvote on 1 Post
Hi, I used epoxy paint over my concrete basement floor, along with a clear topcoat and it turned out good, very happy with it.
I was wondering if I could use the same type of epoxy paint for unfinished wood, specifically, the stairwell that leads to my basement, since it will experience quite a bit of foot traffic, will it be better than regular latex acrylic, or is there a better suggestion (other than staining it)?
Thanks in advance!
Old 08-11-15, 04:12 AM
C
The epoxy works but the issue of a hard glossy surface presents slipping hazards on a stairway.
Any hard wearing finish will have a tendency to be slick. Other possible products would include a waterborne alkyd which gives you a durable finish but again, the harder and glossier the surface, the more slick it will be. You can add an aggregate to help make it less hazardous or glue on a non slip strip to the surface near the stair nosing. Above all, please make sure you have an appropriate handrail.
Old 08-11-15, 04:28 AM
Received 753 Upvotes on 658 Posts
Epoxy can be applied to wood but you need to use the appropriate primer first. The slickness of the epoxy finish can't be overstated! Adding grit to the paint helps but tends to wear off in the high traffic areas. Solvent based or waterborne coatings will wear better than latex coatings.
What type of wood is it? what condition?
Old 08-16-15, 05:11 PM
N
It's just bare, unfinished wood on a stairwell. Thanks.
Old 08-17-15, 03:25 AM
The bare wood will need to be primed first. Many epoxies require a latex primer so read the label and prime accordingly.
Old 08-17-15, 03:32 AM
Banned
Location: 1880 O’Connor Drive, Suite #304. Toronto, ON, M4A 1W9
Re:
Hi friends, i am also use to Epoxy paint in my floor. but that's good in my point of view.!
