Painting Kitchen Cabinet Hinges
Old 08-24-15, 03:56 PM
D
Received 1 Upvote on 1 Post
I looked and looked trying to figure out what category to put this in. I'm not sure this is right, and I'm sure you'll let me know if it's not, but.....here goes.
I am painting my kitchen cabinets. I have tried to find hinges just like the ones I have now, but in black. They just aren't manufactured in black.
I started with the hinges in my laundry room on the two sets of cabinets in there. I tried painting them. I followed the instructions on the spray can to the letter. They looked great.....until......I opened the cabinets. They look all gunked up.
I need to do something to remedy the ones in the laundry room and come up with a better system or better paint product for the kitchen hinges before I start in there.
Any help would be greatly appreciated.
Thank you!
Old 08-24-15, 04:03 PM
Received 758 Upvotes on 663 Posts
Hinges, especially cabinet hinges are probably among the hardest things to get a lasting paint job on. The friction caused by opening/closing will rub off the paint. It's best not to paint them! when you must, a light coat of paint is better than a heavy or multiple coats.
Sandpaper or lacquer thinner will remove the excess paint from the hinge.
Old 08-24-15, 04:20 PM
Handyone's Avatar
http://www.doityourself.com/forum/el...rt-images.html
See above link for how to post pictures. Painting a hinge never works. If you want to go through the trouble, remove doors and hinges from doors before painting. You can then paint doors and cabinets separately. If you want to install new hinges, you would fill old door and cabinet screw holes with a filler such as Bondo or Water putty before painting and then drill for new hinges after paint has cured.
Old 08-24-15, 04:38 PM
Shadeladie's Avatar
Super Moderator
Received 348 Upvotes on 279 Posts
I moved this to Painting. Seems like the best place for it.
Old 08-24-15, 05:08 PM
D
Shadeladie,
Can you give me a link to where you moved it? I looked and looked for a "painting" category, but didn't see one. It's probably right in front of my face. That would be par for the course for the kind of day I've had.
Thanks for the help.
Old 08-24-15, 05:20 PM
Shadeladie's Avatar
Super Moderator
Here you go Donna, Interior Decorating, Design, Painting, Upholstery and Fabrics Center - DoItYourself.com Community Forums
It's under the Interior Decorating, Design, Painting category.
Old 08-24-15, 05:55 PM
Norm201's Avatar
Received 677 Upvotes on 600 Posts
Te only reasonable way to paint the hinges is to powder coat them or have them anodized. You may find a small plating company in your area that might be willing to do them with some other batch of similar color or coating. Look around you might be surprised.
Old 08-24-15, 06:06 PM
D
Thank you! I'm going to check on this in the morning Norm!
