Primer over just paint samples, or whole wall?
Received 0 Votes
I have a few sections of different color paint samples on the wall. I'm guessing it will take a few coats of primer to cover them, but do I have to primer the whole wall each time, or do I just primer over the spots?
I don't want to have different colored spots when I do go to finally paint the wall with the color I picked, so not sure what to do.
Depends, we have no idea if this is bare drywall, already been painted, what color you started with or plan on finish painting.
No paint should take more then one coat of primer over it to cover it enough for paint.
There was no need to prime and already painted wall in most cases.
Still need the colors your working with.
Going to a really dark red type color over a light color then I'd suggest a gray primmer or one tinted to at least 50% of the color your going for or your going to need several coats.
I've seen people having to apply up to 7 coats to get it to even out.
The only reason to use primer over the sample spots is to facilitate coverage. Depending on the color of the primer and the color of the finish paint I'll often just take my roller in the finish paint and spot 'prime' those areas before cutting in and rolling the walls.
When spot priming versus repriming an entire wall the determining factor is generally which is easiest or quickest. If it takes 7 coats of paint to get full coverage - a better grade of paint should have been used!
Received 0 Votes
I just put the primer down before the paint samples because I figured that would give me the truest representation of the new colors on the wall. The wall is an off-white, going to kinda gray/beige-ish colors, but the one sample is very dark compared to the others. So sounds like I should just prime the whole wall and be done with it.
