Painting over Formica / or how to remove Formica
Old 12-07-15, 07:55 AM
Hello, I found an old dresser in the trash the other day, and I'm in the process of repainting it.
The case and drawer fronts are a combination of solid wood and MDF, but the top is the issue. It is a solid wood frame with an 1/8" thick HDF laminate on top, finished with a white formica surface.
I either want to paint the formica, or remove the HDF and formica from the solid frame and make a new top surface from 1/4" plywood.
What is the best primer for painting formica? or, what are some ways I could remove this from the wood frame? It looks like it is glued on with some kind of white epoxy. See photos. Thanks.
Old 12-07-15, 11:31 AM
First let me say it's never a good idea to paint formica but if you must, use a pigmented shellac primer like Zinnser's BIN. The top coat can be your choice of paint [latex, waterborne or oil base]
Old 12-08-15, 10:50 AM
I think it looks fine the way it is and would leave it alone. I would also not use plywood if you disagree with my first statement, as you would see the edge and that's not pretty.
Old 12-09-15, 06:34 AM
stickshift,
thanks for your feedback. I ended up using my heat gun to slowly loosen the glue and pry the formica off the frame work. I will then insert some solid wood segments in between the existing boards and level it all down for a solid wood multipiece top. You are right, the plywood exposed edge wouldn't look good, unless it was filled with epoxy and painted over.
I will post some pics when its all done.
Old 12-09-15, 06:42 AM
You can band the plywood with a strip of real wood to hide the plys. They also sell a 'wood tape' that does the same thing.
