Smelly paint?
Old 01-14-16, 04:56 PM
Smelly paint?
Hello,
I have created a storage space under our interior steps, accessed via a cut-out in the back of a coat closet. The "door" to this space is 3/4" sanded plywood that I primed and painted top coat with paint used to paint our entire patio home (3 years ago). A day after putting the door panel into place, the closet took on a musty smell. A pop-up air freshener has not solved the problem.
Can paint go bad?
Will putting a coat of clear sealer on the panel do the trick?
Any other suggestions?
Thanks in advance.
Old 01-14-16, 07:11 PM
Gunguy45's Avatar
Super Moderator
Yes, paint can go bad. You should have noticed a musty smell from the can. I dunno about the sealer. Have to wait for a Pro on that.
Old 01-15-16, 02:55 AM
Is it kind of an ammonia type smell? While the paint might still be functional [adhere and wear well] latex paints can develop a funky smell when they get old. Generally fresh air ventilation will remove the odor ..... I know easier said than done in a closet.
Solvent based primer/sealers will usually block odors, latex primers not so much.
Old 01-15-16, 08:16 AM
Only advice I can give is to aim a fan into the closet - the more airflow, the faster the smell will dissipate.
Old 01-15-16, 01:00 PM
Exterior paints are not supposed to be used indoors due to whats called out gassing.
If the smell really bothers you, i suggest taking the door off, lightly sand it wipe it down with a damp rag, prime it with say Glidden Gripper latex primer from Home Depot, then top coat it with whatever you want.
Old 01-17-16, 05:54 AM
Re: Smelly Paint
Thanks for responses.
It was interior paint used....wasn't clear in original post.
Did not notice any funky smell when I first applied it.
I've had the door panel in my garage for the past week hoping that would help....it hasn't! I think I'm going to sand it down and purchase some new paint to apply.
Old 01-17-16, 05:59 AM
Some folks are more sensitive to paint odors than others. You might try a low or no VOC paint.
Is it possible to set the door outside for a day or so - that might do a better job of dissipating the odor.
Old 01-17-16, 08:43 AM
Just as a test, I'd paint some other piece of scrap with the paint you have to see if the same thing happens again.
