Baby gate dilema and now holes in the walls
Old 01-22-16, 06:03 PM
D
I'm not sure what my husband and I were thinking when we installed the baby gate at the foot if the stairs like this. The gate only opens 80% of the way because it hits the banister.
Even though we used "bat wing" anchors, it keeps coming loose from the wall. As it did an inch away in it's previous installation.
Any suggestions on how to position and hang this gate?
Also, how do I touch up all these holes? They're so big that it's obvious my husband and I are idoits!
Old 01-22-16, 07:10 PM
D
Hum, my picture uploads keep failing.
Old 01-22-16, 07:12 PM
ray2047's Avatar
Please post pictures of the area and gate. http://www.doityourself.com/forum/li...rt-images.html
Old 01-23-16, 04:38 AM
Received 759 Upvotes on 664 Posts
Is it feasible to move the gate so it can be anchored to a stud behind the drywall?
btw - don't beat yourself up so much, idiots are those that never learn from their mistakes ..... and all of us here have made plenty along the way
Old 01-23-16, 07:43 AM
D
I've tried to attach pictures several times and keep getting a "failed" message!
Old 01-23-16, 07:46 AM
I have trouble posting pics sometimes too It might be possible that your pics are too big and need to be resized before you are able to post them. Another option is to post them on a site like photobucket and then provide the link.
D
It will let me post a screenshot of the error message but not the baby gate!
Old 01-23-16, 08:33 AM
D
Alas! It worked! This is the baby gate at the foot of the stairs.
Old 01-23-16, 08:38 AM
D
Here is a close up of the attachment to the wall. You can see the old holes I attempted to fix after it fell off the wall the first time.
Old 01-23-16, 10:07 AM
ray2047's Avatar
Fasten a vertical 1x4 to the wall.
Old 01-23-16, 10:54 AM
D
Kind of like I did on the right side of the gate? Won't that be more holes though?
And how do I properly repair the existing holes?
Old 01-23-16, 11:03 AM
The 1x4 should cover the existing hole. I'd use toggle bolts along with adhesive to mount the 1x4 to wall. The hole for the toggle bolt should just be big enough to push the folded up nut thru. If you prefinish the front and sides of the 1x4 before installation it will be easier on you.
Old 01-23-16, 12:49 PM
pugsl's Avatar
Received 76 Upvotes on 69 Posts
Do what marksr said, After kids get bigger and no longer need gate holes are easy to fix. Post again and we will tell you how.
Old 01-23-16, 01:06 PM
czizzi's Avatar
Don't use glue, you will regret it more than the holes in the walls later on.
This is for safety at this point not necessarily aesthetics. I would take the left side of the gate and swing the attachment point out so that you can capture the hand railing and secure it to that with some string or wire. You may be even able to share one of the screws that hole the railing into the studs for added support. On the newel post side, also secure the wood to the newel with string/rope or large Zip ties. No holes are needed and you have a secure gate.
