Paint Removal
I have a cast iron fire surround which over the years has been painted with many coats of paint. I bought Nitromorse to remove the paint which it has done to a degree. I seem to have hit some very old lead paint and the Nitromorse is just not sufficiently doing the job, it is leaving a residue - can you suggest a way to remove this.
Thank you.
Thank you.
Your best bet may be to get a stronger industrial strength paint stripper that contains methylene chloride. It's nasty but it works. It should tear right through that paint.
If you use the drill-wire brush combo be careful! It can do a lot of damage in no time. If scratches are what your lookin' for, this is the answer. Otherwise use a liquid stripper.
Toptosher, We don't agree on this topic. You know I still respect you and will always consider you a heavy-weight on this BB.
Red
We do wrought iron hand rails, and the best thing that we have found that works great and it saves a ton of labor, go rent a sand blaster, and have at it, Then if this is go outside you may want to get some red lead primer, this way it'll stop any rusting, then you can go ahead and paint,
Good luck
Frank
Frankawitz Custom Painting &
Plastering Repairs
Good luck
Frank
Plastering Repairs
Received 0 Votes
Yes JDX...Your right,my method is rather abrasive!Thanks for pointing that out.
Ive done this job in the past to remove many layers of paint....with repainting in mind,which hides any fine scratches.
However if redfunky wishes to leave the piece as cast iron then liquid stripper I admit, is the way to go..The paint residue will only go after more nitromors applications and fine wire wool & rags.. and then thoroughly scrub with a stiff brush and detergent.
The luxury of using a sand blaster would be ideal,of course but not always practicle..
