To white-wash or not?
Old 01-26-16, 05:03 PM
I
Would you white-wash this fireplace? This is a photoshopped photo to try to envision it and with the new gas insert(s)Name:  IMG_3172.jpg
Old 01-26-16, 05:28 PM
ray2047's Avatar
Do you mean real white wash, lime and water?
Old 01-26-16, 05:32 PM
I
Paint & water is what my wife says people are using
Old 01-26-16, 06:42 PM
G
Received 2 Upvotes on 2 Posts
Would I do it?
NO. I'm not Tom Sawyer and that's not a picket fence.
If that's what momma wants, I guess you paint it. Be aware that removing paint from brick, in the future, is near impossible.
Old 01-26-16, 06:57 PM
ray2047's Avatar
The brick looks very nice. I can't imagine why you would do that but that's just opinion.
Old 01-27-16, 02:14 AM
Received 753 Upvotes on 658 Posts
One issue with cutting latex paint drastically with water is the resulting coating doesn't wear well ..... so if you do get a decent looking job now - it may not look so hot in a few years. And as mentioned above, once you paint you really can't go back.
Old 01-27-16, 05:44 AM
I
I agree...but she really wants to cause she see's it on "Fixer Upper" all the time #HGTVbrainwash
Old 01-27-16, 06:17 AM
All those home fix up shows on TV need to be taken with a grain of salt. Rarely do they let the viewer know all what is entailed and often they do things that aren't apt to wear well. I've often wondered what some of those houses look like 6 months later.
Old 01-27-16, 07:00 AM
Received 1,197 Upvotes on 1,152 Posts
One more vote for don't do it.
Old 01-27-16, 12:49 PM
F
It has been a few years since I have seen any HGTV programming (cut the cable) but in my opinion almost all of their programming is for entertainment purposes only.
What you could do is let your wife do it if that is what she desires. That at least gives you the, "I told you so" defense. Always worked with my wife. She would tell me to do this or that or whatever and I would try to explain the downside. When she refused to listen (most of the time) I would then tell her to go ahead and do it herself. That alone would almost always stop her and if it didn't it usually didn't go much farther than her just starting the job to lose interest.
Then again, we were only married about eight years when I had had enough and we got divorced. Your mileage may vary.
Old 01-27-16, 02:03 PM
ray2047's Avatar
Real white wash not diluted paint could probably be scrubbed off. My try that first.
whitewash has disadvantages; it is water-soluble, for one thing,
Quote source: Use Whitewash Instead of Paint for Traditional Look and No Toxins - Restoring Mayberry - GRIT Magazine For your application though that is an advantage because it can be removed. To get it semitransparent you would probably need to use less lime. Note there are two kinds of lime . You need hydrated (AKA mason's or builder's lime) not quick lime or garden lime. https://fiascofarm.com/recipes/whitewash.html
