Spraying Lacquer over Poly
Old 05-07-16, 10:32 AM
Can lacquer be sprayed over a polyurethane finish?
Old 05-07-16, 10:39 AM
XSleeper's Avatar
Received 184 Votes on 173 Posts
Yes, you just want to scuff sand the poly first and wipe it with mineral spirits. Anytime you put two dissimilar products together there "may be" some unknown adhesion issues. But generally it will work fine.
Old 05-07-16, 01:42 PM
Received 118 Votes on 105 Posts
Not all lacquers are compatible with oil base coatings so you might want to test a small area first. If it doesn't wrinkle - you should be good to go.
Old 05-09-16, 08:30 AM
Thanks for responses. I appreciate the time you spend on this site.
