Horizontal stripe in garage
Painting a 20x24 garage with white over gray and a 6" blue horizontal stripe between the two colors. The garage floor drops about 1 to 2" from front to back, so my question is: should the stripe be level or should it match the grade of the floor? My gut says level but I don't want it to appear to rise as it goes to the back because the floor is getting lower.
If the stripe is about mid height on the wall or higher I would go for level or parallel to the ceiling. If the stripe will be close to the floor I would match the floor's angle.
Temporarily Suspended
I had a job where I had to add studs. The existing were not plumb. If I made the new studs plumb, it would have looked terrible, so I did them all by eye to match the previous mistake. Anyway, why is the stripe needed, at all?
To Pulpo's point, you might have to split the difference to get it to look good; going off the floor or the ceiling might not end up looking right.
I think you are overthinking this. Level. If you don't make it level, any cabinet on the wall, broom hanging from a hook, or bench/countertop that might be installed later would make the line appear crooked.
I'm with X. The floor is sloped, everything else obeys gravity. Your eye/brain will quickly recognize that it's the floor that slopes.
Ok, that's brilliant X. As for why the stripe because I think it looks good. The strip is 30" above the floor. Yeah, it has to be level to match everything else that might go up. Thanks.
