Danish oil over stain??
Old 08-04-16, 06:55 PM
B
I stained a piece of unsealed furniture (Minwax). I prefer to leave it unsealed for a more rustic effect. Is it acceptable to use some "Danish Oil" over the stain, or should I leave it as is?
Old 08-04-16, 07:03 PM
XSleeper's Avatar
Received 1,899 Upvotes on 1,705 Posts
You can, the new stain will freshen up the old, but dont expect any major change in color.
Old 08-04-16, 07:04 PM
Received 1,261 Upvotes on 1,203 Posts
Leaving wood unfinished means it's more likely to absorb spilled liquids and become permanently discolored. Since you stained, you have somewhat sealed the wood but I would put some kind of protective coat on it. While I personally prefer polyurethane, danish, tung and mineral oil are reasonable finishes as well, though they tend to need reapplication much more often than poly.
Old 08-05-16, 04:11 AM
Received 821 Upvotes on 720 Posts
I'd also recommend using poly [any sheen] Rubbing oil over the stain might loosen up some of the stain and may get smeared around with your rag.
