Painting exterior shutters
Old 04-24-01, 04:00 AM
Guest
I would like to know if you can paint exterior plastic shutters, and if so, what type or paint should I use?
Old 04-24-01, 08:01 AM
Guest
Paint Shutters
A good quality latex paint is recommended for plastic shutters. Be sure to follow the manufacturer's preparation instructions. Before painting, lightly roughen the shutter surface using a medium grade steel wool. This will allow the paint to adhere properly. Next, thoroughly wash the shutters with soap and water to remove any dirt or oil. For best results, two light coats of paint is best. Good Luck!
Old 04-24-01, 07:49 PM
Guest
Thank you
