Is "drywall primer" the same as primer for repainting room?
Old 01-15-17, 06:38 PM
A
Is "drywall primer" appropriate for covering over an already painted room that I want to simply paint another color?
BEHR Premium Plus 1-gal. Drywall Primer and Sealer-07301 - The Home Depot
Old 01-15-17, 06:55 PM
XSleeper's Avatar
Received 899 Votes on 825 Posts
Unless you have a color that is hard to cover up, priming a painted wall is unnecessary.
Old 01-15-17, 07:20 PM
A
It's flat pink that I'm needing to cover up. The impression I get is that it won't really save me on coats of paint, but priming first will have a little bit better results.
Old 01-15-17, 07:49 PM
XSleeper's Avatar
It will work, but a high quality, high pigment primer that is sandable would work better. You always want to lightly pole sand the walls before painting... just enough to knock off imperfections and fuzz that is on the finish.
Old 01-16-17, 03:22 AM
Received 398 Votes on 354 Posts
There are different primers for different tasks. As X stated there isn't really a need for a primer when repainting. The only times a repaint requires primer is when you have to seal repairs, hide stains/odors or to facilitate coverage. Generally 1-2 coats of a quality wall paint will cover the old paint nicely.
Old 01-16-17, 10:11 AM
Received 98 Votes on 86 Posts
If existing paint is oil based and you want to switch to latex, an oil based primer is required.
Old 01-16-17, 03:36 PM
Marq1's Avatar
Received 489 Votes on 453 Posts
No, drywall or PVA primer is for new,patched, or repaired drywall.
Primers like KILZ can be used to cover different types of paints or hide really strong colors.
If you use a good paint, not the krap they sell at HD, then you should not need primer.
I HIGHLY recommend Pratt & Lambert paints.
Old 01-17-17, 08:34 AM
Just a caveat that Kilz Original (oil based) is decent primer but I won't use any other product they make and many pros won't touch their latex primer.
