The old wood laminate sheet on the counter top?
Old 05-20-18, 04:57 PM
I have my wood laminate on the countertop but it's old. Can I paint the counter top look like wood again.? If so how?
Old 05-21-18, 03:48 AM
Received 724 Upvotes on 634 Posts
Pics would be helpful. If it is indeed a wood laminate you should be able to sand it lightly an refinish. A lot depends on it's current condition.
Old 05-21-18, 06:05 AM
XSleeper's Avatar
Received 1,648 Upvotes on 1,476 Posts
I assume this is a continuation of this thread.
https://www.doityourself.com/forum/c...h-problem.html
And this thread.
Replace the same color Laminate Sheet?
He just doesn't get it.
Old 05-21-18, 09:42 AM
Laminate kitchen counter top?
I have my laminate kitchen counter top. It's too old so I am going to paint it looks like wood. Do I remove the laminate sheet, or Is it ok to keep it. I will paint over it. What do you suggest?
Old 05-21-18, 10:12 AM
P
Received 1,713 Upvotes on 1,529 Posts
It will be very difficult/impossible to remove the laminate. That is a pre-formed counter available at most home centers. I would replace it with a new counter. If you don't want to replace the counter I would just leave it as is and not paint it. If you do wish to paint it I would look at a counter painting kit. A painted counter will scratch easily so you will have to be very careful with it once it's painted.
Old 05-21-18, 10:17 AM
2
Received 301 Upvotes on 257 Posts
If that blemish in the picture is the only problem, you could rout out the area and install a decorative tile, or a piece of solid surface (Corian) or even a piece of real butcher block to serve as a hot pad or cutting board area.
Old 05-21-18, 10:40 AM
Gunguy45's Avatar
Super Moderator
Received 5 Upvotes on 5 Posts
Threads merged. Surfbug...one problem...one post.....do not ask multiple questions all over the site about the same issue. You already asked about replacing the laminate or painting last week!
