Removing Paint Marks from Wood Beams
Old 05-15-01, 11:32 AM
Guest
I just purchased a conod. The ceiling has several wood beams. The beams are very rough and are stained in a dark stain, possibly mohogany. The beams were not taped off prior to painting the walls and have paint covered roller marks on them.
I would like to restore the beams. I might be able to match the stain. I need to remove the paint first. Any suggestions?
Old 05-15-01, 08:55 PM
Insulman
I'm not 100% sure about this but a product "goof off" might just do the job
Old 05-16-01, 02:22 PM
Guest
Paint on beams
If the beams were stained and then covered with a clear finish and if the paint was a latex, you should be able to scrub off the latex paint even though it has dried. If the paint was an oilbase paint and the beams were not finished with a clear finish, you could try to scrub off some of the paint and then you would have to use a similar color stain, perhaps even a gelled stain because it has more opacity, to touch up the beam.
