Knocking down old paint in crevices - there has to be a tool
Old 07-29-18, 08:20 PM
Received 1 Vote on 1 Post
It's taking me forever to sand within these crevices, is there some sort of sanding tool that can easily get into crevices to sand?
Sort of like a hairbrush with surrounding bristles but the bristles have a certain grit.
Anything come to mind or is there a technique to sand into the sucky design of these wheels?
Old 07-29-18, 08:55 PM
Received 1,187 Votes on 1,098 Posts
Are you trying to remove all the paint ?
If you are..... you'll never sand it all off.
You'd need look into sand blasting or chemical stripping.
Old 07-29-18, 08:57 PM
I only want to scuff it enough to repaint it.
Old 07-29-18, 09:06 PM
Emery cloth (crocus cloth) is fine grit sand paper on a roll. That may be helpful.
A wire brush in a drill may work.
Old 07-29-18, 09:15 PM
XSleeper's Avatar
Received 720 Votes on 666 Posts
You could also get a 3m sanding sponge (the thin pads that are 4x6 or so) and cut it into strips.
Old 07-29-18, 09:30 PM
Good idea. Even the ScotchBrite sponges with the green back will work to scuff the paint.
Old 07-30-18, 08:49 AM
I'm thinking a fine wire wheel or flapper wheel that attaches to my drill is the best option
