Getting bubbles applying drywall paste over paint
Old 08-02-18, 04:23 PM
Q
Received 1 Upvote on 1 Post
I'm getting some bubbles applying drywall mud over a very dry painted section of wall.
is there a way to stop this or stil it style when the mud dries?
I assume it's the paint underneath lifting
Old 08-02-18, 05:14 PM
XSleeper's Avatar
Received 1,900 Upvotes on 1,706 Posts
You can mix just a little more water in with your mud. Another tip would be to lightly mist the wall with a few spritz of water from a mister.
Old 08-02-18, 05:56 PM
Q
If I let it dry would a wet sanding remove the bubbles? I had added some water to this premix already to make a smooth finish.
or add a very thin topping coat tomorrow?
Old 08-02-18, 06:10 PM
XSleeper's Avatar
You will need to sand, wipe dust off, and skim coat.
Old 08-02-18, 07:49 PM
Tolyn Ironhand's Avatar
Received 867 Upvotes on 730 Posts
Some people add a little dish soap to prevent pock marks. I will just go over the mud enough to pop them all (most). If you still have some after the mud dries you can sand the off and to a light skim coat, as Sleeper suggests.
