Best way to fix bad edging job
Old 09-09-18, 02:46 PM
P
So this was my first attempt at painting an entire room by myself and kinda rushed into it without doing my usual research ahead of time. Anyway, i taped off the entire ceiling and the wainscoting but noticed when I pulled off the tape I did a pretty inconsistent job which resulted in the following examples. My question is after cleaning up the edging, should I do a quick once over over the entire wall again or should I be good to go after the touch ups?
Old 09-09-18, 03:13 PM
XSleeper's Avatar
Received 1,900 Upvotes on 1,706 Posts
You don't generally need to use tape. Just a steady hand. I like sash brushes for cutting.
Old 09-09-18, 03:17 PM
P
Yeah I figured that out after the fact unfortunately. As for best practices for fixing my mistake, should I reapply paint to the entire wall after the touchups?
Old 09-09-18, 03:45 PM
XSleeper's Avatar
You might be able to just cut the edge in with a brush one more time, and that's it. Whether or not the sheen shows will depend on the quality of the paint and how well it was stirred each time. Use a small brush, you don't need to paint 3" wide.
Old 09-09-18, 03:51 PM
Tolyn Ironhand's Avatar
Received 867 Upvotes on 730 Posts
I agree, skip the tape. I also use a angle cut sash brush for cutting in and typically spend $10-$15 for a nice brush. When cutting in I find it helpful to wipe off the paint on side of the brush that will be on the side of the woodwork. It helps me keep paint from going where I don't want it.
Old 09-09-18, 04:22 PM
P
Yeah I am using Behr Marquee. I actually went and bought an angle sash this morning, so I will just cut it and see how it looks. Thanks for the suggestions!
Old 09-10-18, 03:28 AM
Received 824 Upvotes on 722 Posts
A little late but I agree, touch up or recut in those areas with a brush. A 2" sash [angle] brush works best for most diyers. The odds are just cutting in the affected are will be satisfactory. You won't know for sure until the paint dries.
Old 09-10-18, 08:55 AM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
Forget the brushes, forget the tape.
Pick up a Shur Line pad edger and you will knock out the entire room in 20 minutes with a perfectly straight and level paint line.
Not sure about the newest models but I have better luck moving the pad on the trimmer away from the ceiling to allow a 3/16" to1/4" gap.
It helps keep the paint out of the corner and makes a better line.
https://www.doityourself.com/forum/a...1&d=1536591248
Old 09-10-18, 09:55 AM
XSleeper's Avatar
Maybe I don't understand but I think the 1/4" gap is the peoblem... not the solution.
Old 09-10-18, 11:57 AM
Marq1's Avatar
It's the inconsistency of the line that is the problem !
Old 09-10-18, 01:51 PM
XSleeper's Avatar
I'm not sure how that would help his bottom picture unless you like seeing the previous color of wall paint. Trim color.... previous wall color... new wall color. A straight 1/4" strip of yellow on the wall isnt what is want to see.
