Stucco paint sq ft per gallon
Old 09-18-18, 12:36 PM
I am repainting the exterior stucco wall. Internet says 200-300 sq ft per gallon. Is 200 for fresh stucco and 300 for painted surface? Thank you.
PS: I am going to put Walmart Color Place Ultra 100% acrylic paint. Pressure washed. Paint is mostly intact.
Old 09-18-18, 04:00 PM
Marq1's Avatar
Received 95 Votes on 86 Posts
It all depends on how rough the texture!
You'll find out as soon as you start painting!
Old 09-18-18, 07:37 PM
Thank you for the explanation. Now I understand why the range.
Old 09-19-18, 02:43 AM
Received 120 Votes on 107 Posts
Painted stucco won't require as much paint as bare stucco but bare stucco really should be primed first.
What shape is your existing paint in? If the paint is chalky [and won't wash off] you need to either apply a masonry sealer or add Flood's Emulsa Bond to the first coat of paint. As stated above how rough or what texture the stucco has determines how far a gallon of paint will go. Paint will go a lot further on a sand finish [smooth] stucco than it will on real rough stucco.
Old 09-21-18, 09:55 AM
Since all my neighbors have the same stucco finish, I have no reference for smooth/rough. I used 4.5 gallons for 900 sq ft, that is, 200 sq ft per gallon. I suppose I have a rought stucco. Old paint was adhering well. It survived pressure wash.
Thank you.
