Wooden rocking chair painting
Old 10-10-18, 06:06 PM
I am attempting to repaint some rocking chairs that were on my porch and am not getting very good results. Here's what I've done:
Washed them with Jomax cleaner, rinsed with power washer. This left a mix of some bare spots but mostly spots with some paint remaining.
First tried several light coats of spray paint and primer in one. That looked OK in parts but a lot of parts didn't cover well. I then went back and tried some primer and that helped but still didn't cover uniformly.
Any suggestions on what to do next?
Old 10-11-18, 12:03 AM
Marq1's Avatar
Received 1,209 Upvotes on 1,098 Posts
Have you sanded down the wood after the cleaning and before putting on the primer?
Old 10-11-18, 12:55 AM
Received 1,230 Upvotes on 1,179 Posts
Spray paint is seriously diluted paint; takes an awful lot of spraying to cover.
Old 10-11-18, 04:08 AM
Just a very quick once over with some fine sandpaper, but that's it.
Old 10-11-18, 04:42 AM
Received 785 Upvotes on 688 Posts
I'd brush the chairs, that will apply a thicker coat of paint, work the paint into the wood better and give longer lasting protection. It's too difficult to apply enough paint with a rattle can to get good coverage or lasting protection.
Old 10-11-18, 06:15 AM
OK, thanks. I'm thinking because of some of the uneven coverage, I should maybe do another light sanding now. What do you think? How about deglosser and/or a brushed on primer before painting?
Old 10-11-18, 06:45 AM
Liquid deglosser should only be used on old finishes, it's not intended for fresh primer or paint.
A light sanding between coats is always a good practice!
