used wrong colour paint
Old 03-16-19, 04:12 PM
Received 1 Vote on 1 Post
I recently painted over an area on my kitchen ceiling, but used the wrong colour of paint. I used a light grey, however, the correct colour is white. What is the best way to fix this? Do I just match the correct paint and roll over this area? The grey paint I used was an interior eggshell enamel "paint and primer in one". Any advice is appreciated. Thanks.
Old 03-16-19, 04:16 PM
XSleeper's Avatar
Received 670 Votes on 620 Posts
You need to repaint the entire ceiling with your desired color if you want it to match. Ceilings are usually "flat ceiling white."
Old 03-16-19, 04:52 PM
I'm not too worried about it matching as it's only the ceiling. Could I just paint it white over that section or will the darker colour show through?
Old 03-16-19, 04:56 PM
XSleeper's Avatar
If you have the exact paint that was used, you might be able to do it, but the sheen may still show up as different. If you don't have the exact paint that was originally used, then like I said, you will need to repaint the entire ceiling.
Old 03-16-19, 04:58 PM
maarkr's Avatar
Received 8 Votes on 6 Posts
make sure you get 'ceiling' paint, and you will notice it but won't be terrible. like xsleeper said, to do it right, u need to do the whole ceiling.
Old 03-16-19, 05:48 PM
Received 94 Votes on 83 Posts
And quit using that gimmick crap paint.
You sound determined so go ahead and get the white paint and try to touch up the spot. If it works, great. If we're right, just make sure you bought enough to do the whole ceiling.
Old 03-17-19, 02:22 AM
Received 318 Votes on 282 Posts
Unless the paint job is recent and the exact same paint is used it's difficult to get a touch up in the middle of a ceiling to blend. IF you get the same color paint and touch up over the wrong color it will look better than it currently does but the touch up will likely show. A light scuff sand is the only prep needed.
