Need Input Regarding Sanding Interior Trim Before Repainting It
Old 04-04-19, 08:00 AM
T
Currently I'm in the process of prepping to repaint the trim in my kitchen and I need advice.
Here are the details.
- trim is currently painted with oil based Benjamin Moore Imprevo oil paint that is shiny and smooth ( can't remember if its satin, semi-gloss or gross but definitely looks glossy)
- I'm in the process of sanding it
- I plan to put a coat of Kilz Original oil based primer over it to be followed with BM Advance semi-gloss water bourne enamel
Here is my concern:
I've tried sanding the old trim with every grit of sandpaper from 120 to 60. When I rubbed my finger over it the area sanded felt rough. But when I wiped off the sanding dust with a damp sponge the trim looked and felt smooth.
So I'm questioning whether I need to sand it more before I prime the trim?
Or am I over thinking this and the fine scratches created with the sandpaper despite the apparent smoothness will allow the oil primer to properly adhere?
I appreciate and need your input so I do not mess this up
Thank you
Old 04-04-19, 08:28 AM
Received 754 Upvotes on 659 Posts
You are over thinking it. I generally do a quick sand with 120 or 150 grit prior to applying the primer or next coat of paint. The minute sanding scratches are enough to promote adhesion.
Old 04-04-19, 08:41 AM
T
That's what I was hoping to hear. Thank you Mark
