Just painted wood threshold...how should I finish it?
Old 04-24-19, 07:14 AM
A
I painted it at 6pm ish last night and will apply a second coat today. The temp will be in the mid 70's for the next couple days and was wondering how I should finish the project to ensure a long lasting finish (because this door is by far the most used). Any suggestions?
Old 04-24-19, 10:06 AM
Marq1's Avatar
You just painted it, your done!
Old 04-24-19, 10:12 AM
What type of paint did you use? Ideally it would have been a floor enamel.
Old 04-24-19, 10:43 AM
A
It's a Valspar ext. paint+primer.
And I just wondered if I should apply anything to finish/seal.
Old 04-24-19, 10:48 AM
House paints don't get a clear coat like car paints do. I'd be inclined to leave it as is for now and then in a yr or two when it shows signs of wear, sand and apply a coat or two of a porch and deck enamel.
Old 04-24-19, 11:19 AM
A
Ok sounds good thank you!
Old 04-24-19, 08:39 PM
Received 1,179 Likes on 1,137 Posts
The proper finish is a quality paint.
Old 04-24-19, 09:21 PM
XSleeper's Avatar
Received 1,584 Likes on 1,419 Posts
Yeah, a High gloss Oil enamel if you can get it (the Porch enamel that marksr mentioned) is usually best. Not all paints are made to go on trim and doors.
