I cause my own problems. Oil based primer then latex paint? A problem?
Old 07-03-19, 06:01 PM
E
I primed some 2x6s going on the outside of a shed. I used an old can of 'alkyd exterior primer' in my collection of paints in the basement and figured I'd use it to get rid of it.. I put the primer on and then went to rinse the brush in a water bucket... and realized that it was oil based. I woulnd't have thought I had any oil based products.
Will that be a problem when I paint over it with behr premium latex satin exterior paint?
Old 07-03-19, 06:08 PM
XSleeper's Avatar
Received 1,534 Votes on 1,378 Posts
No that is not a problem. In fact it's probably better.
EdShnatter voted this post useful.
Old 07-03-19, 06:09 PM
E
Thanks you!! 1 less issue!
Old 07-04-19, 04:04 AM
Received 681 Votes on 602 Posts
Latex paints can almost always be successfully applied over dry oil base primer. As X noted, the oil base primer will do a better job of sealing the wood than it's latex counterpart.
Old 07-12-19, 11:10 AM
G
Received 2 Votes on 2 Posts
Latex will go over any primer. Oil based paint will go over anything. The only time you have a problem is if you try to put latex based paint over oil based paint.
Old 07-12-19, 11:23 AM
E
novice me.... I think of primer being not that all that different than paint.
Old 07-12-19, 12:37 PM
Actually it's ok to apply latex house paint over weathered oil base house paint. Generally it's not a good idea to apply exterior oil base paint over latex. Inside the rules change as oil base will do fine over latex paint but latex won't always adhere if applied over oil base enamel.
