Exterior wall texture/cinderblock house
Old 06-02-01, 04:28 PM
Guest
I own a cinder block house and would like to texture the exterior walls enough to hide mortar lines. Is there a way to do this without using full-blown stucco technique (supported by framing/chicken wire, etc)? I'm hoping I can spray or hand-apply a product directly to the walls and then paint over. I live in Seattle, so rain is an issue. Any suggestions? Thanks.
Old 06-02-01, 05:32 PM
Guest
www.elastek.com
I have a house made of painted cement brick, and considered doing the same. Living in the southwest, a large number of houses are built with stucco finishes, and it's easy to find someone to do it for you inexpensively. However, there is a company here in Tucson called Elastek that specializes in a one-application coating that seems to work well. My neighbor used it with very good results. Use the following link to get more info about them and their product. They are a well-established business and I think you can trust them. Maybe they can put you in touch with a distributor in your area. Good Luck!
http://www.elastek.com/datashts/323.html
Old 06-02-01, 05:55 PM
Guest
I think I didn't give you the home page. Here it is. http://www.elastek.com Or you can go to this page of their site and see them applying it to exterior walls.
http://www.elastek.com/stucco.html##323
