Sanded interior MDF door, prep before paint?
Old 06-05-20, 11:52 AM
I did a final sand of 220. Do I need to do anything before I apply paint?
Old 06-05-20, 12:19 PM
Received 315 Votes on 279 Posts
You'd want to prime the areas where you sanded too deep. They may need a light sanding again after the primer dries.
Old 06-05-20, 03:21 PM
Marq1's Avatar
Received 364 Votes on 340 Posts
Not sure why you needed to get that deep but unless you prime and sand as mentioned there is a good chance that that spot will show through the paint!
Old 06-05-20, 03:24 PM
XSleeper's Avatar
Received 666 Votes on 616 Posts
Either way there is a good chance it will show through the paint. MDF is flat, i'm afraid you must have sanded a dip into the door to make it look like that. If the paint has any sheen at all, the dip will show up in the sheen of the paint.
