Sanding wood with uneven grains?
Old 07-31-20, 10:31 PM
A
I'm trying to strip paint off this patio cover beam. A belt sander just scrapes the top. What tool would you use to get into the grooves?
https://i.imgur.com/eJR9Lpq.jpg
Old 07-31-20, 11:09 PM
Marq1's Avatar
Received 880 Votes on 802 Posts
Your using it, if a belt sander with a heavy grit paper doesn't sand that down, nothing will!
Old 08-01-20, 12:46 AM
A
There must be some sort of circular sander for this type of job.
Old 08-01-20, 03:38 AM
Received 600 Votes on 533 Posts
You could sand out the grooves [and paint] with either a belt sander or 7" sander/grinder. If you want to leave the grooves you'd need to use a chemical stripper.
Old 08-01-20, 03:54 AM
Norm201's Avatar
Received 558 Votes on 498 Posts
Or use those "sponge" type sanding blocks that conform to the profile of the work piece.
Old 08-01-20, 06:57 AM
XSleeper's Avatar
Received 1,448 Votes on 1,304 Posts
If you thought a belt sander was slow, any other sander will be much slower. A belt sander is likely the best tool to use because you need to flatten those grooves, not detail sand each one. Change the grit to have the intended effect. 36/40 grit is aggresive, higher grits remove scratches. Finishing with 80 and 120 are probably as high as you need to go if it's getting painted.
AndyRooney voted this post useful.
Old 08-01-20, 07:47 AM
Norm201's Avatar
So that is suppose to be smooth piece? To me it looked like it was scalloped to be that way. Maybe the picture was too close up.
Old 08-01-20, 08:18 AM
A pic from further back would be nice. I assume it's just a severely weathered piece of wood.
Old 08-01-20, 10:07 AM
A
Yes it is "scalloped". I don't need to scrape off 100% of it. I just want paint to grab onto something solid.
I'm thinking a plain old wire brush might work good enough. This is a beam that runs the span of a patio cover (seen in one of my other posts). This side of the beam will not even be visible, so it doesn't have to be perfect.
Old 08-01-20, 10:46 AM
XSleeper's Avatar
I see. You can use a wire brush, or they make wire brushes and paint strippers that you can put on a drill.
Old 08-01-20, 11:29 AM
A
Tried just a hand held wire brush. Not really cutting it. I need some sort of sold scraper with teeth.
Old 08-01-20, 11:42 AM
Tolyn Ironhand's Avatar
Received 551 Votes on 473 Posts
Try a grinder with a wire wheel or wire brush. Be sure to use proper PPE! It will throw a lot of debris. They can be VERY aggressive.
Wire wheel: https://www.harborfreight.com/4-1-2-...eel-91282.html
https://www.harborfreight.com/5-inch...eel-66975.html
Wire cup: https://www.harborfreight.com/3-inch...ush-47927.html
https://www.harborfreight.com/4-in-c...ush-60321.html
Old 08-06-20, 11:31 AM
A
I got some sanding belts with the highest coarseness. This seems to work the best.
