Fuzzy (oversanded) new drywall paper
Installed new drywall, and at the edges of where I applied mud (the joints and screw dimples), I oversanded so the non-mudded areas adjacent to the mudded areas have drywall paper that is a little fuzzy. If I prime and paint (2 coats of color), is the difference between the smooth mudded areas and the adjacent fuzzy drywall paper going to be very obvious? Even to people who aren't looking closely at the paint?
If so, what's the easiest way to fix the fuzzy drywall paper? Can I spray Kilz Original on it to seal, then skim with mud? Or mud directly?
I had someone go crazy with a power sander and fuzzed a lot of paper. You can either skim coat with mud and properly (lightly) sand. Or, prime the area and sand after the paint had cured like XSleeper said. It works better if you wait to let the primer get hard so it sands to dust instead of gumming up your pad.
cartman voted this post useful.
Thanks. If I can get away with skipping any more mudding and going straight to priming with a good quality primer followed by light sanding (which I'd have to do after priming even if I didn't have this fuzzy drywall paper issue), that's an easy call for me!
