Painting a wood railing
Old 05-03-21, 06:59 AM
N
Hi. We just had our finished basement painted, and we did the doors in a nice dark blue semigloss.
We also asked him to paint the railing (wood handrail) in the same blue. The handrail is a typical wood rail that had been stained. He sanded it, primed it, but then painted it using the white semi-gloss baseboard paint, rather than the blue.
Can we just paint over it with the blue, or would it need to be primed again first? And, in any case, if/when we paint it, would you recommend a roller or a brush? I assume roller to avoid brush strokes but I wasn't certain.
Painting was completed a couple of days ago.
Thank you.
Old 05-03-21, 07:12 AM
Marq1's Avatar
Received 505 Votes on 468 Posts
Primer helps paint adhere better to the "item" so that has been done, paint to paint is good.
Just sand it down to a dull finish and clean off the dust.
Personally I would use a brush, sounds way to small for roller and if your using good paint and a good brush, paint strokes should never be an issue!
Old 05-03-21, 09:10 AM
Received 408 Votes on 364 Posts
A scuff sand before applying the blue is sufficient. I'd also recommend using a brush.
Old 05-04-21, 06:59 AM
N
Great, thank you. I'll give it a try.
