Cigarette smoke/Covering up with paint
Old 06-28-01, 08:21 AM
Guest
Hi,My husband and I just bought a house where the couple smoked for 22 years in it. I tried to wipe down the walls, but to no avail it seeps right back through. What could I use that isn't extremely expensive to seal the walls. I'm looking for something semi-cheap because the house is 2500 sq.ft. and I'm going to need a lot of it.
Old 06-28-01, 01:16 PM
Guest
Many people use a solvent based stain blocking primer to seal out smoke damage and smell. One coat should work and then you can use one or two coats of a good latex to finish the job. You will probably have to scrub the wood work also to get the smell out.
Old 06-28-01, 04:30 PM
mikejmerritt
lisakirkendall, KILZ Original is about 11.50 in my area, drys fast and goes a long way. I think this is what I would use. Don't believe anyone when they say latex based primer sealers will hold back smoke stains...Mike
