Painting galvanized steel deck
Seeking advice. What type of paint can I use on a steel beam and a galvanized steel deck? The beam and deck are 13 years old supporting a second-story balcony. Some surface rust nothing horrible. For the surface rust I am using a nylon brush on a power drill (easy work). Quite a bit of oxidation (white powder) which comes off fairly easily with white vinegar. From what I have read online I should be using an acrylic paint. Does this sound right? A Rustoleum product? Need to prime first? Looking to paint a flat or semi-gloss black. Thanks in advance for any recommendations on process and paint brand/type selection.
Latex paints often adhere better to galvanized than oil base does but any rusty steel should have an solvent based primer applied first. I'd be inclined to prime the entire surface with oil base and then when dry apply a latex finish.
If I was to try and finish with just 1 coat I'd probably spray it with an oil base flat black. Should wear ok since it's not exposed to the elements.
Thank you Mark. Any concerns of an oil base not adhering properly? From what I have read online the galvanized steel has a coating that oil paints don't adhere to very good, and over time the paint may peel away. It's been 13 years so I'm sure some of the protective coating has worn off. Wiping it down with white vinegar to remove an coating might help.
They make specialized paints and primers for galvanized metal, I've never had the need to paint galvanized metal but would probably do some research.
