help
Old 07-12-01, 08:53 AM
Guest
Exclamation
we are repainting the bath in our new home
we peeled the wallpaper all off down to the primer
upon a closer look the previous owners had half removed more wallpaper and decided to prime over it then wallpaper over that.
I want to paint
How will i remove those strips of wallpaper that are primered over on drywall that wasnt primed?
Do I give up and re drywall the whole room???
is there a way to remove it??
Old 07-12-01, 09:15 AM
BSB's Avatar
BSB
BSB is offline
have you thought about spackeling the walls to give a uniform texture and then painter over that?
I think I am using the term correctly.
If you try to remove the old primed over wall paper you may end up pulling the paper backing off the sheetrock its self. I dont think you want to have that effect.
if you can "I" would feather the lines, prime and paint.
Brian
