Primer For Covering Alkyd
Old 09-13-23, 12:36 PM
W
We have alkyd paint in the interior of our home. We want to recover with a fresh coat of latex. I’m confused with what product to prime the exsisting
material. A big box store told my wife Behr Multi Surface and stain blocking primer and sealer will
properly prep the surface. I don’t want a bonding issue.
Old 09-13-23, 02:57 PM
XSleeper's Avatar
Received 1,810 Upvotes on 1,628 Posts
I'd probably use an oil primer like Kilz original. Oil to oil for good adhesion. You can put your latex on the oil primer.
Old 09-14-23, 03:04 AM
Received 1,231 Upvotes on 1,179 Posts
Stop going to a store that sells Behr is step one. Going to an actual paint store would be step two. Kilz original would be ok but I prefer Zinsser primers myself. Short answer is you need an oil based primer and then you can cover that with your quality latex paint.
Old 09-14-23, 03:51 AM
Received 785 Upvotes on 688 Posts
I agree, use an interior oil base primer to insure adhesion of latex over oil enamel. There are a couple of latex high grip primers that claim to adhere well to oil enamel but I don't have any hands on experience with them,
Old 09-14-23, 02:18 PM
W
I appreciate your responses.
I need to avoid the use of high VOC products. My 101 yr old mother also lives in this home. I’m in Michigan and it’s September I can’t leave the place open to air out 24/7. Looking for experience based advice on a proper water based primer.
Old 09-14-23, 02:47 PM
XSleeper's Avatar
If you absolutely have to use low VOC, then I'd use SW PrepRite ProBlock. Keep in mind low VOC does not mean a product is odorless... just that it's not toxic. I dont find it offensive. But everyone has a different tolerance for odors. The longer you can let it dry before topcoat, the better. Lightly pole sand it to remove imperfections before topcoating.
https://images.sherwin-williams.com/...179.1692570742
Old 09-14-23, 09:56 PM
"proper water based primer"
I have yet to find such a thing.
