I need to remove layers of old paint
Old 07-25-01, 09:10 PM
Guest
Unhappy
I am looking for a product I saw on T.V. only once. You brush it on, and it is green, when it is done working it turns white, and you can easily scrape off many layers of paint at once. It will also remove stain without raising the grain of the wood. Can anyone help me find this product, or at least give me the name of this stuff?
Old 08-08-01, 06:41 PM
Guest
Smile i need to remove layers of paint
I asked the same question. I don't know if this stuff is the item you are looking for, but it is called PEEL AWAY. I don't know where you are located, but they have a web site and you can ask for a distrubutor. It was too expensive for me as I had to to 356 sq ft. and it was 29.00 for enough to do 25 sq. ft. good luck.....their web site i believe was http://www.peelaway.com
Old 08-08-01, 07:22 PM
Guest
Thanks for the info, I think I saw the website you mentioned, it is to expensive for me too. I have four rooms of wood work to do, I guess I will just have to use the stuff in the local home center. I hate that stuff, I always have, it just stinks.
But thanks for the help.
