painting steel door
Old 09-08-01, 06:06 AM
Guest
Unhappy help
i recently bought a stanley steel entrance door.it's very nice with some glass in it. it came primed so i lightly sanded it ,used tact cloth then painted. i used a ben moore oilbased gloss and applied with a foam roller.i expected a glossy finish but didn't get one. in some places its ok but in
others it looks bad. what did i do wrong? 2 coats on.
* i really need some ideas on how to correct this problem.
should i use a latex over past coats? strip it and start again?...help
[Edited by dk7726 on 09-14-01 at 04:39]
Old 09-17-01, 09:39 AM
Guest
This could be caused by a few things. It could be that the primer on the door has a few spots where the film is not as heavy as the spots around it and it will absorb the paint that you put on more then the surrounding area, causing a low gloss area. It could also be that you are not applying your topcoat on at a consistent build over the entire door which could cause low gloss in the areas that do not have enough paint. Consider doing this: lightly sanding the door again and put on a third coat. Put down enough paint so that you get enough film build to allow the paint to flow out and give you a gloss. Or you could sand down the present film. Put on another primer. Use a stain blocking primer and then put on another coat or two.
