Preparing trim
Old 01-06-02, 06:55 AM
Guest
Preparing trim
Hi,
My home is 3 years old and has settled in considerably. We want to prepare home in order to repaint. I have noticed that our walls and trim now have a considerable gap due to settling. How do I get rid of this gap? Do I apply caulk or am I to use screws and find the studs and pull the wall and trim together? Or is there some other way.
Thanks
Old 01-11-02, 07:17 PM
Guest
YOU DONT WANT TO USE SCREWS. TRY CLEANING THE TRIM AND WALLS AND SANDING THEM A BIT. IT SHOULD HELP THE FIT.
CLAIRE
Old 01-11-02, 08:21 PM
T
You have just entered.........THE TWIGHLIGHT ZONE!!!
It really depends on how large the gap is...
More than 1/4 of an inch ,then you should really screw them back..
Less then that??...Well ,flexible decorators caulk will be fine..
