paint problems
Old 01-17-02, 09:16 AM
Guest
Question paint problems
How do you fix an uneven paint job...I started the painting in the worng order...painted the body of the walls first and then the corners and frame ...now the body is lighter than the corners and frame...how do i fix that?
Old 01-17-02, 09:38 AM
The Soulgirl
You need two coats anyway so go over it again using a paint pad as that will get you right close to the edges so you wont need to cut them in again.
