Flat paint over gloss
Old 02-27-02, 02:59 PM
grease_monkey
Have moved into a home where someone has used
gloss paint to touch up some walls that were
painted with a flat paint. I want to cover this
with flat paint is it okay to clean the wall and
just paint directly with flat?
Thanks
Old 03-02-02, 12:56 PM
jlob66
No, not really. Scrub the shiny areas with TSP (or substitute) and sand lightly; there is also a product called Liquid Sand, but I have never used it. Wipe down thoroughly. People will tell you that you do not have to do this; they are wrong. Actually, it's not much more work than prepping any wall for painting, but you really do have to rough up the glossy areas.
Old 03-03-02, 09:28 AM
KeithP
Good answer....also, the gloss basecoat may cause a 'flash' through the flat topcoat....best in my opinion to prime that one wall first, better still the whole room ( as the job will look better and you'll use less paint) and the you be pleased.
