Waterstain on my ceiling
Old 03-02-02, 01:17 PM
Colleen Mahoney
I have a small water stain on my ceiling and I am wondering if there is a method and or product that I can use to remove it, without having to repaint my ceiling?
Any suggestions?
Old 03-03-02, 08:24 AM
KeithP
Removing it might be a headache...if the ceiling is clean, try hitting the stain with a light mist of B-I-N spray primer (alcohol-based, shellac) or Benjamin Moore's S.P.S (similiar product)...they are white, dry fairly flat and you may not notice the touch-up...if the ceiling is smooth, rather than textured however, you may notice a 'flashing' of the repair, it will appear shinier than the rest of the ceiling because the primers dry glossy and the ceiling paint is likely flat...if so, spot prime the stain, then run a quick coat of paint across the ceiling to hide the primer.
Old 03-09-02, 04:28 PM
keck
I was able to get regular bleach to work. I put it in a spray bottle and covered the floor with pastic and it took the yellow right out. Its worth a try.
