i want to cover my panelling
Old 04-10-02, 06:37 PM
hollienh122
i want to cover ugly dark panelling. i heard of a trick to cover the panelling with brown wrapping paper coated with a pollyurthane mix. then paint it. was told this will seal the lines in panelling and create a textured wallpaper look. has anyone ever haerd of this?
Old 04-11-02, 12:33 PM
W
To quote from some of my posts on the wallpaper side of the house:
About brown bagging:
http://forum.doityourself.com/showth...ighlight=brown
About just plain covering up paneling:
http://forum.doityourself.com/showth...threadid=88109
Old 04-14-02, 07:24 AM
tsparky79
painting panelling
Start by sanding your panelling then run caulk down the seams makeing shure you smooth it out with your finger.Then use a good oil base primer I like kills no stains will bleed through. Then put you two coats of latex paint over it. Hope this will help
