Priming
Priming
When should you prime and what is the best way to do it? Do you need a specific type of brush or roller?
Some instances include:
Drastic change of color
Painting over oil with latex
Painting non-porous surfaces (laminate, panelling, varnish, plastic, tile, glass, chrome)
Sealing a porous surface (drywall taping seams, patches, old chalky porous paint, masonry, wood)
When using a deep, clean, dark color
Covering stains and odors (water, smoke, tannin, knots, crayon)
To ensure uniformity of sheen and depth of color
Painting bare metals (ferrous especially)
To seal in lead-based paints
To eliminate grafitti
For each job, there is a corresponding primer, a correct primer. Many are water-based, some alkyd (a synthetic oil-based product), some oil (with true linseed oil in them) and some solvent (ie alcohol or shellac-based). Some are junk, full of chalk. The applicators will be dictated by the type of primer used, but generally, a synthetic brush (polyester, nylon) and a 3/8-3/4 inch nap sleeve will do.
Keith
Keith
