Problems painting over caulk
Help -- I painted over caulk and 1 week later it shows noticeable cracking.
Here's my story: As part of a DIY dining room remodel, I recently built and installed some window seats and added some molding. I applied caulk to seal the gaps between the molding/seats and the wall. I had no idea what type of caulk to use, I took the advice of the guy at Home Depot (I know, I know, that was my first mistake
). He recommended DAP dynaflex 230 (see http://www.dap.com/retail/retail_det...=1&prodhdrid=4). I applied the caulk according to directions, and it had plenty of time to cure (it was at least 2 weeks) before I painted it. I didn't use primer, but did apply 2 coats of an interior flat latex. I noticed the cracks beginning to form around the window seat almost immediately.
Should I have used primer or a different kind of caulk? More importantly, is there anything I can do now, short of removing the caulk and repainting?
According to the web site, this caulk is paintable. Is the paint not adhering to the caulk, or is it cracking where the caulk meets the wood? I suspect the window seats have shifted, due to use or the wood is shrinking / expanding. The caulk stays flexible, but the paint is less flexible.
I've experienced the same thing on outdoor joints that have been caulked - although it takes a full season for the joints to shift and the paint to crack.
A better option would have been to find a latex caulk in a matching color. You could have applied this after painting, leaving the caulk unpainted. I've even customized latex caulk by adding a bit of latex paint as a colorant.
I don't want to tell you to rip out the old caulk and start over. Maybe someone else has a better idea......
I really hope I don't have to. I'd almost rather leave it the way it is, even though it looks bad.
I think the paint is adhering. For the most part, there is coverage and I can't make it flake off or chip using, e.g., my fingernail or a putty knife. But I am getting cracks both along the length of the bead and crosswise. It almost looks like a weatherized/crackle faux finish, except that wasn't my intention and the rest of the wall has a solid, non-crackled coat in the same color.
