03-12-00, 12:19 AM
How do you paint paneling that has already been painted? Should we prime over the existing paint or would sanding it do the trick?
03-12-00, 10:00 AM
Assuming that there are no areas on the paneled wall that need additional attention, you would paint them as you would any other pre-painted surface.
Primer would only be necessary if you are changing from an oil based to latex, or if you are also changing the surface texture.
MTAC - VB,MO
www.carpenter.cjb.net
Home repair & Construction
"Where the character and work are always upright"
MTAC - VB,MO
