painting painted paneling
How do you paint paneling that has already been painted? Should we prime over the existing paint or would sanding it do the trick?
Assuming that there are no areas on the paneled wall that need additional attention, you would paint them as you would any other pre-painted surface.
Primer would only be necessary if you are changing from an oil based to latex, or if you are also changing the surface texture.
MTAC - VB,MO
www.carpenter.cjb.net
Home repair & Construction
"Where the character and work are always upright"
MTAC - VB,MO
