Cost of Addition to existing home
Old 04-24-00, 08:23 AM
Guest
Lightbulb
We have a standard ranch and would like to add an upstairs addition (28' X 32') consisting of 4 rooms and a bathroom. Is there a table that we can use to figure what this job would cost.
Old 04-24-00, 04:54 PM
Guest
Post
You can figure about $50.00 per square foot, plus taking off your old roof.
Jack the Contractor
Old 04-24-00, 05:14 PM
Guest
Post
Thank you for the information. Would we figure 50.00 a sq ft if we just wanted to build a weather tight shell? Basically Frame, roofing and siding. We want to do as much of the work ourselves, as possible.
Old 04-29-00, 05:10 AM
Guest
Post
Jade:
You may have to figure more. The real expense is taking off your existing roof, framing and putting on the new roof. When I said $50.00 a sq ft. I was taking into consideration all the items that do not cost that much. so it balances out to $50.00 a sq ft. The framing and enclosing are very expensive and could go as high as $75 a sq ft. Good Luck
Jack the Contractor
