tjis and flooring
Old 06-17-03, 07:03 PM
al valdez
tjis and flooring
I am building a new house . We have set the tjis and are ready to put the 3/4 tongue and groove wafer board flooring.
Is it o.k. to use glue on the tjis and then nails or should i use deck screws, also should I use metal floor bridging or is there
a better way to brace the tjis? Thanks for the help. al
Old 06-17-03, 08:18 PM
Tn...Andy
Definity use subfloor glue.....it will eliminate a LOT of squeaks later.
Nails are what is commonly used.....screw would be great if you have a driver that uses the screws on a strip and has the long handle so you don't bend over all the time using it....otherwise it's a lot of labor.....
Use the metal bridging.
