Sawing Paneling & Blade Type
Old 01-31-04, 01:22 PM
jsuper
Saw Blade
I AM GOINGTO INSTALL PANELING IN MY BASEMENT. DO I NEED A SPECIAL BLADE FOR THE CIRCULAR SAW?
Old 01-31-04, 01:39 PM
C
No. The regular carbide blade will do.
Old 02-01-04, 06:32 AM
jsuper
Sawing Paneling
WHEN CUTTING A SHEET OF PANELING SHOULD THE PANELING BE FACE UP OR FACE DOWN.
Old 02-01-04, 06:40 AM
Dave_D1945's Avatar
Received 1 Upvote on 1 Post
What kind of saw are you using? Cut face up on a table saw and face down with a circular saw. You want the point of the teeth to cut the "good" side.
Whichever saw your using, put on a fine toothed blade.
Old 02-04-04, 06:41 AM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
My Two Cents
Hello: jsuper
A fine tooth blade will produce the best finish results. Cut only one end of the paneling. Allow the molding to be used to cover the cut end or side cut.
Be sure the panel being cut has good support beneath it. Helps to produce good cutting final results. As will as new blade specific for cutting paneling.
Blades can be obtained at the lumber yard where the paneling is purchased, any local hardware store or check in the diy store.
DIY'S Power Tools & Accessories:
http://doityourself.com/store/power...accessories.htm
(copy & paste)
Regards and Good Luck, Sharp Advice.
Web Sites Host, Forums Monitor & Sharpening Forum Moderator.
Accurate Power Equipment Company. Complete Saw and Tool Sharpening Services. TCB4U2B2B Enterprises. Sharp Advice Business Management Services.
Reminder: "Work Shop Safety Is No Accident."
